Sym Tyre Question
Discussion in 'General Scooter Discussion' started by Neilvx, Aug 5, 2013.
  1. Neilvx
    Neilvx New Member
    Vespa GTS SuperSport
    Hello,
    My Sym Jet 4 125 has odd size tyres as standard which is making it hard to find a matching set with good grip.
    The front is 120/60-13
    The rear is 130/70-12
    I was looking at a Maxxis tyre or something as I miss the grip I get from my bigger bike.
    The question is as I am struggling to find a decent make that does a 60 profile for the front could I up it to a 70 profile. I guess I would have to up the rear to a 80 profile to keep the bikes stance for handling ??
    Any help is always great
    Neil
  2. MARSH
    Yes it's the front which is odd, the rear is a std size. If I owed the Sym I would fit a 130/60-13 tyre on the front and a 140/70-12 on the rear. But don't take my advise on this matter as correct but it's what I would use. The std front tyre 120/60-13 are about £100!!!!!!!!!
  3. Neilvx
    Neilvx New Member
    Why would you change the width other the height ??
  4. MARSH
    Because the 130/60- 13 tyre is easy to get hold of plus fitting a wider tyre will belly out to make it slightly taller (diameter) on the thin rim and do the same to the rear to compensate the front.
  5. Neilvx
    Neilvx New Member
    Would it not ruin the handling, well the handling it has got lol
  6. MARSH
    ? maybe but for the price of two tyres I'd try it! If your unsure then you'll have to buy original fittment tyres.
  7. Neilvx
    Neilvx New Member
    Could I get away with fitting 130/60-13 front and 130/70-12 rear.
    Would it matter that the front and rear tyre match being 130 wide ??
  8. MARSH
    Lots of scooters use same size tyres but usually the rear is wider.
