sym jet
Discussion in 'The Workshop' started by JaMeZ, Jun 4, 2008.
  1. JaMeZ
    JaMeZ New Member
    hi i was wonderin if any1 has any ideas why my sym jet isnt going properly, ive got it working now and ticking over nicely, i just put a new plug in it and cleaned out the carb but wen ever i get on it to ride it keeps kinda bogging and trying to cut out but if i let the throttle go its alright. so its kinda almost cutting out at high revs. ive tried messin with the idle mixture but no luck.
    cheers for any advice! :D
  2. alex_1966
    alex_1966 New Member
    main jet is too rich probly , check the plug to see if it is and then down jet a tad
  3. JaMeZ
    JaMeZ New Member
    cheers wat wud the plug look like if it is?
    cheers
  4. alex_1966
    should be dark , the perfect coulour is a nice diarreaha brown
  5. JaMeZ
    JaMeZ New Member
    ha ha cheers mate
  6. JaMeZ
    JaMeZ New Member
    unfortunately the plug is a nice diorreaha brown so dont think its the main jet anyways i had a look at the jets and im sure there standard.
    so any1 else got any ideas im so stuck i have no idea wat it could be
    cheers
  7. alex_1966
    clean the airfilter , maybe check the rollers for flat spots
    is the bike tottaly standard ?
  8. JaMeZ
    JaMeZ New Member
    yeh as far as im aware its totally standard ive cleaned the airfilter, ill check the roller but could that really be the cause of it cutting out when i pull the throttle?
    cheers
  9. capri dave
    capri dave Active Member
    I reckon this could be a float problem or a blocked main jet....
    too lean a mixture will cause bogging at full throttle, as well as too rich ;)
  10. alex_1966
    yeah was thinking could be a blocked main jet but he said he cleaned the carb lol
  11. JaMeZ
    JaMeZ New Member
    yeh im well stuck ive cleaned the jets a couple of times and tried tweaking the mixture loads but to no avail :(
    ive looked at the float boal if thats wat u mean and it doesnt look like anythings wrong with it but im not sure wat id be looking for with that. so how could i see if it is a float problem n ill check it.
    thanks very much for your help guys
  12. alex_1966
    does the float move up and down smoothly ?
  13. Sw1fT
    Sw1fT Active Member
    200SX S13
    reeds? air leak somewhere?
  14. numanoid1704
    numanoid1704 New Member
    float
    to check the float take it out the carb and see if its got fuel inside it.if you cant see through it give it a shake instead.
