SUZIKI KATANA 50LC
Discussion in 'General Tuning' started by eddo241, Jul 1, 2008.
  1. eddo241
    eddo241 Member
    NEOS
    HELP ANY1 IT FLYS FROM 0-34 THEN ITS LIKE ITS RESTRICTED.
    GET A LITTLE DOWNHILL IT WILL GET TO 40 THEN THATS IT BUT SOMETIMES IT WILL ONLY DO 31 EVEN ON THE FLAT SO BASICLY THE TOP SPEED VARIES FROM 31-40?+WOULD LIGHTER ROLLERS HELP?
    ALSO ANY 1 KNOW WHERE TO GET A BETTER CDI THAN THE STANDARD 1 FITTED 2 THE BIKE?
  2. Mehmet
    Mehmet Active Member
    AUDI A3
    Have you take out the washer in the vario..... and are you sure ...
    Because it should get to 40-45 on straight
    And cdi is only for it to go over the rev limiter which i DOUBT you can get anywhere near lol.
  3. WOLFFY
    WOLFFY New Member
    Katana's go silly slow speeds. I've got 2.
    They are quick off the line, but thats about it....
    Wont be going any where fast with out a bore on one really.....
  4. Dec
    Dec Active Member
    nothing ugm
    i think i remember capri dave saying the standard gearing is set mega low, look for a gear up mate and have you checked the carb for restrictors?
  5. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    my old sr had the same engine as katanas do(morini) a polini iron 70 kit,19ml carb,technigas pipe,polini vario and belt,malossi clutch and e13 filter and that was touching 62 pmh true speed, didnt have a gear up either.
  6. eddo241
    eddo241 Member
    NEOS
    will check an let u know by the sounds of it must b a restrictor sumwhere
  7. eddo241
    eddo241 Member
    NEOS
    think ill just have wobbly rebuild the engine its gettin old and tired.
  8. one7twoboi
    one7twoboi New Member
    CAPS PLEASE EDDO!!!!!!!! :rofl:
