Surprise fooking surprise, my peds playin up again (video)
Discussion in 'The Workshop' started by harrisp, Oct 2, 2007.
  1. harrisp
    harrisp New Member
    Well my peds making a funny noise and I was wondering if you all knowing lot could help me lol.
    I'm getting really pissed of with this now...so the problem is its making a funny noise, seems to be coming from transmission, have a listen to the video, listen to when i come off the revs, its like a whining down sound, O and my ped is sound really rough on idle.
    Thanks in advance I owe everyone on here a lot for all the help.
  2. tweak
    tweak Member
    First things first, your rollers are too light/small/worn.
    Next, sounds like a bearing in the transmission whining
    Thirdly, does your wheel turn whilst at 'idle?'
  3. harrisp
    harrisp New Member
    Its just started doing it so im guessing its not rollers worn, how can you tell there to light? there just the ones that came with my exhaust.
    Yes my wheel turns at idle, why?
  4. tweak
    tweak Member
    The rollers are not sitting correctly in the variator due to flats/lessened diameter/weight and so they rattle at idle. This is common when people mix roller weights too.
    With an idle speed your wheel should only try to move, so your clutch springs are worn or incorrectly adjusted (dependent on type of clutch) etc and catching on the clutch bell.
    Try and locate the whining noise from the transmission casing using your ears whilst someone else revs the scoot a little. Gearbox shaft, output or clutch bearing possibilities, but on listening to that again suspect the belt is actually rubbing... so is it new/old/good condition?
    Have you been inside the transmission at all?
  5. harrisp
    harrisp New Member
    What weight rollers should I be going for with a leovince exhaust and a pm tuning crank?
    Standard clutch with standard clutch springs.
    Last time I had the cover off was about a week a go to spray it.
  6. wobbly_trials
    thats a lovely noise on a minarelli, aahhh reminds me of the countless miles on the area51
  7. harrisp
    harrisp New Member
    You ever find out what the noise was?
    This is a piggy engine.
    thanks for all the help everyone.
  8. wobbly_trials
    will probably be the same thing, its the bearing that the shaft that goes through the rear wheel spins in.
  9. harrisp
    harrisp New Member
    Ive found out what it is, the dick heads at the bike shop that did the nut up on the end of my crank put a fucked nut on and it came lose and its buckled my clutch which has now cut a groove into the casings.
  10. wobbly_trials
  11. Admiwal Wabbit
    Admiwal Wabbit Member
    if it's just a groove on the inside of the casing then it's not much damage really.
    But still, the shop shouldn't have put a wrecked nut on there.
  12. alexsr70
    alexsr70 New Member
    what bike shop did you go to mate?
    just so we can keep away lol :pimp:
    if you need any parts for the sr now i got loads, plus most are mint too
    just gimme a pm and i will sort you out nicely
  13. harrisp
    harrisp New Member
    So im probably looking at new cases, new crank (Again) with all the seals and bearings to go with it, a new clutch plus labor putting it all together. :( :(
  14. alexsr70
    alexsr70 New Member
    wait a sec whats the damage to the crank?
    i fort it was just a groove in the casing and warped clutch?
    trust me the groove shuld be fine (i mean its a groove) and clutch can be replaced it cant be that bad again mate, can it?
    get some pics cos uno that everyone on heres gna help out as much as possible
  15. wobbly_trials
    its not the crank, its the shaft the clutch goes onto.
    unless ofcourse he means the variator.
  16. alexsr70
    alexsr70 New Member
    true true well
    lets just wait for sum pics and then everyone can try help out
  17. harrisp
    harrisp New Member
    The nut holding the variator has come loose has probably cut a groove into the crank like it did last time.
  18. alexsr70
    alexsr70 New Member
    well chek first
    and find out what needs to be replaced
  19. harrisp
    harrisp New Member
    took it to the shop that fucked it 'cos I cant undo the clutch.
    Will be having words with the lad who did it when I've got my ped back.
    they let an apprentice do it.
  20. Nitro-Rhys
    Nitro-Rhys Active Member
    i disagree with this shit an apprentice ok every1 gota start somewhere but not on customers bikes who are paying full labour price for a pro to look at it. il be taking mine to taffspeed i think soon or servernside motrcycles and il be watching what they doing, wouldnt surpirse me if they say it took twice as long? :(
