Sub frame..
Discussion in 'Scooter Tuning' started by climax, May 27, 2007.
  1. climax
    climax Member
    2x Italjet Dragsters
    right im thinkin off gettin a sub frame so i can have my carb at the top... is that alll i need to do this or do i need a jack up ect? or what?
  2. MiNoR cOnFuSiOn
  3. wobbly_trials
    that's what i was thinkning. :confused:
  4. Kieran
    Kieran Active Member
    st
    kiesler subframe?
  5. Nrg-Jay
    Nrg-Jay New Member
    Hes on about, what Kieran said, basically on aeroxs the carbs are pointing towards the belly pan outer sight, he wans the modified subframe that like either will make it longer by 10cm or the one that actully stays the same but instead of the engine mount going straight thru so the carb carnt sit at the back it goes around making it possible to put carb so will stick out at back.
  6. climax
    climax Member
    yeh that one ;)
