Stupid aerox, still not running properly
Discussion in 'The Workshop' started by MattWadz, Mar 28, 2011.
  1. MattWadz
    MattWadz Member
    Piaggio Zip RST 50
    Okay, my aerox is still not running properly, it was running like crap, so i fitted a new head and gasket and then it worked ok for about 2 hours, then starting running like crap again, whats wrong with it, the idle stays okay until i rev then it stays very high, unless i tap the choke, ive played with the screw and it doesnt do anything, should i just change the carb? and when i go more than half throttle, or when i slow down so the rpm goes down it just stops until i rev it a bit and it sounds like theres not enough fuel, can someone please tell me if i should just bin the whole bike or what should i do?
    thanks
  2. bandyleg
    bandyleg New Member
    Anything That Moves
    A good starting point would be to check all your cables are running freely if you have to tap the choke it sounds like something is sticking, this isnt a defo fix but would be a good starting point.
  3. kylespeedfight
    kylespeedfight Active Member
    New Gilera Runner 70
    sounds like choke sticking on
  4. MattWadz
    MattWadz Member
    Piaggio Zip RST 50
    its nearly fixed now, just gotta wait for my bigger jet
