Stunt 70cc Set Up minerelli vertical engine
Discussion in 'Scooter Tuning' started by dezze, May 9, 2007.
  1. dezze
    dezze Member
    Hi everyone
    i was just wondering about a couple of set ups and which one u guys think would work best.
    set up 1
    Polini Corsa 70cc Kit
    Polini ForRace Exhaust
    Polini oversised reed vaulves and 21 dellortho carb
    Set up 2
    Malossi MHR replica 70 cc
    Malossi MHR replica exhaust
    Oversised vaulves and 21mm carb
    Personaly i prefer Polini and it works out a lil bit cheaper than the mallossi
    but i want the best set up posible so im askin
    THANKS DEZZE
  2. liamspeedy
    liamspeedy New Member
    have you got a race pipe already?
  3. MiNoR cOnFuSiOn
    id always go polini over malossi.. but you should use a diff pipe with ether (i know polini/malossi state you should use there pipe but there refering to max power over a stock pipe) there are better matched pipes out there but they WONT advertise other companys for free... would you?
  4. dezze
    dezze Member
    i have a basic tecnigas pipe that i got with the bike
    and a mallossi variator and an athena 70cc alloy 1 ring kit but the kit is hurt
    so im looking to do a complete engine overhaul.
    Still to put in 25% harder cluch springs
    wat pipe would you guys sugest with the polini set up ?
    i heard yasuni make really good pipes.
  5. climax
    climax Member
    2x Italjet Dragsters
    i would say yasina c16 love it :D
  6. MiNoR cOnFuSiOn
    to be honest. if you slam an iron kit on with the best pipe for it (not a yasuni) it wont be as fast as the athena kit you have.. id be sniffing around the mhr rep malossi kit with a c16 or for a little less the iron kit (polini are cheaper) with a gianelli reverse pipe.
