Stuck on gear up kit
Discussion in 'Scooter Tuning' started by Rox_power, Apr 1, 2016.
  1. Rox_power
    Rox_power New Member
    I'm looking for some help on which few gear up kit I should do its all pretty new to me here is my build so far with more to come
    Stage 6 r/t qtr turn throttle
    Head light up grade with angle eyes
    Stage 6 280mm brake upgrade
    4 pot brake calliper to match
    2 brand new Pirelli tyres
    Stage 6 Kevlar belt
    Str-8 vented case cover
    Stage 6 dash with revs and water temp plus more
    48mm pod filter
    Stage 6 r/t 24mm carb 38 pilot jet 120 main
    Stage 6 inlet tract
    Stage 6 v force 3 reeds
    Stage 6 racing mkii 70cc kit hpc
    Stage 6 hpc full circle crank
    Stage 6 over size vari with 3.5 g
    Stage 6 torque control clutch
    Stage 6 clutch bell
    Rebuilt water pump with genuine pump kit
    Run on motul 800 full syn oil
    Kevlar belt
    R1400 pipe
  2. romain
    romain Member
    Yamaha tmax
    Sorry by gear up kit
    What do you mean ?
    The actual transmission gear right?
  3. Rox_power
    Hi yes sorry for the mix up yes I mean transmission gears as I have such a big kit I have been told I need to put a gear up kit in to use it to its full potential
  4. romain
    romain Member
    Yamaha tmax
    It really depend how you are using your bike
    If you don't mind it screaming but havinga crazy good acceleration you can keep the standard gear
    If you rather prefer having your bike capable of higher top speed and screaming less when than fit a higher gear kit don't get me wrong you will still have good accelaration but not as hard as with oe gear
    Since you seems to like stage 6 bits
    Why don't you go with there gear kit ?
  5. Rox_power
    I do plan on going stage 6 gears as well but there as different primary gears and I'm unsure which one to get as I don't want to get to big of a primary gear or it would be a waste. And then I'm unsure if I need a secondary gear as well
  6. romain
    romain Member
    Yamaha tmax
    Three things ,
    you haven't told me what your top speed is ?
    What you want of your bike great acceleration or great speed ?
    And what bike is it ?
    If they do let say only one secondary gear and two or three primary just change the one they only do one of this way you will be able to see which gear ratio you have as standard and work out what you can or want to do
  7. Rox_power
    Top speed on gps is about 85-90kmh. I would probably want to improve that to about 110kmh maybe a tad more I can afford to loose some acceleration as I make so much torque
  8. romain
    romain Member
    Yamaha tmax
    Yeah 85/90kmh it must be screaming
    You still haven't told me what your bike is
  9. Rox_power
    Doing about 11900 rpm at that speed. It's a 05 aerox
  10. aeroxman87
    aeroxman87 Member
  11. romain
    romain Member
    Yamaha tmax
    I thought of the malossi but he would like it stage 6
    As he got most of it stage 6
    The malossi will need to be pressed tho
  12. aeroxman87
    aeroxman87 Member
    You can use secondary gear kit 15/39 from stage6.
    The reduction factor will be the same as malossi primary kit
    Standard primary 13/52 + Stage6 secondary 15/39 = 10.40.
    It's pre pressed and easier to fit than primary gearing.
    mattyjk8 likes this.
  13. Rox_power
    Hi thanks for the reply as I'm trying to keep my build stage 6 what about the stage 6 13/43 primary
  14. mattyjk8
    mattyjk8 New Member
    im in the process of a similar build. im going to do what aeroxman suggested and get the stage6 secondary gear kit.
    am i right in thinking you would only need to change both if you were running a high end kit?
  15. aeroxman87
    aeroxman87 Member
    Stage6 13/43 primary It's about the same as Stage6 secondary 15/39 as I suggested to you over here. But Stage6 secondary are easier to fit, because you dont have to press the primary shaft thru the bearing in the gear cover!
  16. aeroxman87
    aeroxman87 Member
    It dosent matter if you change primary, secondary or both, it's the total reduction factor that matters. Sometimes you have to change both to get reduction factor you want.
