Stub matching
Discussion in 'Scooter Tuning' started by italjohn, Dec 25, 2007.
  1. italjohn
    italjohn Member
    Hello to you all. I just want to show you some pictures of my stubmatching on my Runner 172.
    Original Malossi 172, and stainless stub from Scooter-Center.
    Before
    After
    And some porting of the cylinder. The casting must be opened equaly.
  2. capri dave
    capri dave Active Member
    nice one john...i guess the engine is up and running by now.
    I remember when you started building it up on gilera runner.net :D
    Hows she go??? any recent pics or vids john :D
  3. italjohn
    italjohn Member
    Hello Dave.
    Yes she has been running, but I have not got the carb set up correct yet, so I`m still working on this. Now its cold here in Norway, so I have put her on hold for now.
  4. capri dave
    yeah its pretty cold here now john...i cant wait for the weather to start warming up in a couple of months....so much to do ;)
  5. hotwot
    hotwot New Member
    What advantages is there to opening up the exhaust port?
    Wont you have to open up other area's to match?
    Why did you chamfer the edges of the cooling channels?
  6. MiNoR cOnFuSiOn
    bigger port means more power but less responce.. also matched pipe works best with least wasted air..
    what cooling channels? the part he ground is a transfer port feed..
  7. hotwot
    hotwot New Member
    lol :emb: sorry..i see now
    I ask so many questions...they call me Mr q at work...
  8. stevegti2
    stevegti2 Member
    i have had a stub for my 59 once that matched up perfect and others that havehad varying lips now thats quality control
    steve
  9. MiNoR cOnFuSiOn
    not the stubs.. its the barrels ;) 59 stub only matches in the tiny unmodded size it is anyway... pants tbh
  10. stevegti2
    stevegti2 Member
    so the standard exhaust ports are too small on the 172 you say ok
    steve
  11. italjohn
    italjohn Member
    If you use the stock exhaust, everything is ok, as this one has a narrower outlet that matches the small exhaust on the cylinder.
    But I did use the stainless stub from SC, and this have a much bigger opening, as you can see on the pictures.
    Original
    Tuning with no restrictions
  12. MiNoR cOnFuSiOn
    those need alot of weld floated in them tho then ground back as its a rounded edge not a sharp flat cut.. will never match a rounded edge hence you have to grind them too big for any kind of power under full revs.
  13. stevegti2
    stevegti2 Member
    ah i see the object on the standard pipe is to round that flat lip good job i enjoy welding
    steve
