Strange transmission issue - Yamaha neos (Minerelli 50cc AC)
Discussion in 'The Workshop' started by NJH, Apr 21, 2008.
  1. NJH
    NJH New Member
    Hey.
    I have a 2001 yamaha neos, which is fully restricted (exhaust, variator) which goes around 56 clock speed.
    I have fitted lighter rollers, 4.5g instead of the standard 6.5 :msn1: which makes the acceleration a load better, and the revvs actaully stay steady throughout the power, with this setup its nippy enough for what I use it for, and reliable.
    But I have noticed, when you accelerate, upto 7mph it goes very slow, hardly revv's, then it will suddenly revv up and power up to about 50mph clock speed. Anyone know what this is?
    And also, if have my transmission apart, when I put it back together, it runs really well etc, but after about 70miles it will take longer to accelerate etc not revving as much, but if I simply take the transmission cover off, undo the cutch and variator, take these off, then put it all back together it will run really well again, so like WTF :confused:arc:
    Anyone got any ideas or help/advice?
    Many thanks
  2. NJH
    NJH New Member
    just to add, when i take the tranny apart and put it back together, its still slow upto about 7mph.
  3. alex_1966
    alex_1966 New Member
    clutch springs ?
  4. pow
    pow New Member
    Does the bike rev quite high when on the spot until the clutch bites?
  5. NJH
    NJH New Member
    nopeee. but like i brought some from beedspeed, like +15% +45% and + 70%, ive tried all of them and stock and theres like no difference :confused: but i was thinking it was the springs, but its just strange. any know about the decrease in performance?
  6. MiNoR cOnFuSiOn
    stiffer clutch springs.. the delay is the engine being under load below the powerband so it takes a while to build up.. stock setup SUCKS
  7. NJH
    NJH New Member
    tbh, thats what i thought, becuase wen it gets to like 7mph it's at the revv's where it just pulls and pulls.
    so i need some springs, anyone got a set spare, or what shall i get, i think the ones from beedspeed are shit, how can i know which are going to be stiff enough? i dont mind them being a lil bit too stiff either
    and will a contra make much difference whilst ive got the clutch apart?
  8. NJH
    NJH New Member
  9. alex_1966
    a box of clutch springs with 3 sets in are a about a tenner of pm tuning. get them and try each set until you find a set that works well :beer:
  10. NJH
    NJH New Member
    yeh. i brought some from beedspeed and wus still shite, i think they was shite springs, but i havnt really got £10 +p&p to spend on them
  11. alex_1966
    its the only way you can sort it out , nobody can tell you exactly what spring to get just like jets and rollers
    get a job ;)
  12. NJH
    NJH New Member
    i got a job,. but i spend money on other stuff
    its so much hassle doin clutch springs, jus wana throw one set in
    will i need to change the jettin as its re'ressed?
