Strange Problem after putting to standard.
Discussion in 'General Tuning' started by AeroxSam, Nov 17, 2010.
  1. AeroxSam
    AeroxSam New Member
    I had quite a high sport setup on my a/c nrg power.. but i decided to put it to standard and fitted a whole new engine.
    Ive put my old coil, and all electrics are the same as i had working perfectly on my 70.
    The problem is... i accelerate off the line it hits a barrier of about 8k revs and then just cuts out (revs fall) and once i roll off the throttle its fine untill i accelerate again.
    Whole bike is now standard exhaust, carb, bore. However i have a 56jet instead of the standard 53, that shouldnt give this much fault should it?
    Thanks
  2. capri dave
    capri dave Active Member
    the jet doesnt sound massively big, around 5% larger than std, but if everything else checks out ok, your going to have to try a 53 jet just to eliminate it from the possibilitys....
    is the spark plug fresh, ive had a plug before that would break down every time i full throttled, but seemed ok at 3 quarters throttle :glare:
    also are the rollers std weight, and you havent fitted a new kevlar belt recently have you ?
  3. AeroxSam
    AeroxSam New Member
    Belt is standard, and i THINK the rollers are standard, im so dumb for not remembering that but ill try the jet tomorrow, but if it isnt that then i think rollers will be a high possibility. Ive spent so much money cos i need it sold :L and i bought a fly puller for no reason cos i thought it was the stator.. thanks dave.
  4. capri dave
    im sure you could sell the fly wheel puller on, without too much of a loss :)
  5. AeroxSam
    AeroxSam New Member
    well i have put the standard 53 jet in.. and same problem occurs.. so im going to try rollers, what is the standard weight and dimensions of a piaggio nrg power 50cc a/c ?
