Strange noise
Discussion in 'The Workshop' started by White aerox, Feb 2, 2008.
  1. White aerox
    White aerox New Member
    OK i have recentyl had my 70 kit fitted on my aerox and about 2 days ago it started making a noise everytime i let off the throttle its hard to explain it is like a wooshing sound type of thing its like i am riding then let of and it goes woosh its very weird it only happens at low revs as wen i am riding fast and let off it only goes woosh again wen i am near low revs its very weird hope u can help
  2. Mehmet
    Mehmet Active Member
    AUDI A3
    erm i think it could be a wrong set up ???
    i dont really know much but its weird coming from a 07
  3. White aerox
    yeh i no it sorta sounds like i have a dump valve wen i let off the throttle lol its very strange hope it isnt damaging my bike
  4. wobbly_trials
    clutch catching up. clean your clutch out and see if it helps?
  5. White aerox
    ok thanks alot wobbly i am actually changing my standrd belt to a top performance belt and putting my harder polini clutch springs in so i will clean it all out
  6. wobbly_trials
    yeah, it sounds like something in there is either slipping or dirty, use a paint brush to get all the belt dust out.
  7. White aerox
    ok thanks i will tell u if that sorts the problem out i hope its not the cylinder it was fitted by a professional and i watched him do it
  8. polini118
    polini118 New Member
    WOOSHING FROM ENGINE
    I HAVE THIS SAME PROBLEM ON MY TGB R50X/70cc..
    ITS MY STARTER COG 4 THE ELECTRIC START BEHIND THE VARIATOR.. IT KINDA WOBBLES ON DE-ACCELERATION OR SUMMIN DUNNO IF IT DOES ANY DAMAGE
    ** SOUNDS FU#KIN WICKED THO **
    I FIXED IT BY PUTING A WASHER BETWEEN THE STARTER COG AND VARIATOR BACK.. WORKS MINT
  9. Dann
    Dann New Member
  10. wobbly_trials
    all i can say is LOL and thankyou dann
  11. Dann
    Dann New Member
    I'm guessing you never fitted the kit yourself, so take it back to whoever fitted it and ask them about the problem, it's a long shot but you never know and they might sort it out and get them to fit your belt etc free of charge.
    Hopefully isn't do damaging though so fingers crossed.
    No problem Wobbly, it bugs me as much as it humors me too :punk:
  12. Mehmet
    AUDI A3
    Haha lol nice one ;)
  13. Dungbug
    Dungbug New Member
    lol! :D
  14. White aerox
    ok i have just fitted my new belt and fitted my green polini clucth springs but the noise is still there lol it is starting to piss me off and guess wt i have another problem now my hd lead keeps coming off my spark plug lol i just ride for 10 secs and my bike cuts out plz help me getting annoyed
  15. Crana
    Crana Active Member
    I got the same problem, everytime I hit a pot hole it comes off and my bike cuts out :(
  16. White aerox
    yeh lol duno wt am guna do
  17. Adam:
    Adam: New Member
    I had the spark plug problem a while back. Take the spark plug out, clean out the ht cap and then screw it on to the spark plug. Put the spark plug back in and sorted. Normaly happens if you get a little bit of dirt in the HT cap.
  18. White aerox
    ok thanks will do that
  19. White aerox
    Ok people i have now changed my belt and clutch springs and the noise is still there any other ides what it do be the noise is hard to explain i will try make a video all i can say is that when i pull off and at low revs it make a woosh or chhh sound just say chips in your head lol the ch sound dont no wt it cud be??? help plz
  20. Masetw
    Masetw New Member
    I know this sounds silly but i had the same problem and it was nothing to do with the engine mine was to do with the brake discs being warped and the run out was makin it run on the pads which was making the noise long shot but better than nothing mate
