strange idle
Discussion in 'The Workshop' started by aprilia123, Aug 18, 2008.
  1. aprilia123
    aprilia123 New Member
    hi guys, my ped idles very weird e.g. sometimes it will just cut out and not idle at all after letting revs off, or the revs wil drop very low to the point where it nearly cuts out then they will pick back up to normal idle speed. any ideas why? cheers
  2. alex_1966
    alex_1966 New Member
    bad choke-o-rama or blocked idle/pilot jet
  3. baz172
    baz172 Member
    or an air leak check ya inlet manifold to see if it looks cracked anywhere and tighten up ya jubilee clip that holds ya carb on
  4. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    check the bolts on the head are all set to the correct torque, my sr 70 used to do that before i tightened to bolts up correctly
  5. Vesta
    Vesta New Member
    My NRG does this all the time never thought much about it, changed the idle tickover on the carb and it made it a bit harder to cut out still does it when cold tho
  6. aprilia123
    cheers for help guys im going to change my inlet manifold as it looks very worn.
  7. aprilia123
    wt prt of barnsley / wakey r u frm vesta?
  8. Vesta
    Vesta New Member
    From Hemsworth mate, if you know that
  9. aprilia123
    av erd of it. am jus wonderin cos am frm barnsley anol
  10. Vesta
    Vesta New Member
    were you from?
  11. aprilia123
    worsbrough m8 heard of it?
  12. Vesta
    Vesta New Member
    yeah mate i've heard of it, if you know were cudworth is am 2mins from thea
