Stock Aerox Crank
Discussion in 'Scooter Tuning' started by 2strokeracer, Jan 10, 2008.
  1. 2strokeracer
    2strokeracer New Member
    Sgoin on people.
    Just had my 06 Aerox tuned to a Malossi 70cc Sport kit, with some extra clutch parts. But at the time i did not have the correct size rollers so they had to use the stock ones.
    Anyway..... When i am cruising down a main road where im weaving in and out of traffic at around 85 kph (50-55mph) my engine is screaming it balls off. The bikes done about 2500kms so its fairly new, so i was wondering if i will need a better crank?
    OR,
    I have a Laser X Pro with new rollers and jets coming from Scooter Attack.
    Is it the stock rollers making it scream or do the engines just scream at those speeds? Because its only going to scream more with the new exhaust.
    Cheers for your help.
  2. Dec
    Dec Active Member
    nothing ugm
    get a gear up mate i had the same problem now my bike happily sits at those speeds without screaming 'one more mph and i go bang'
    dec
  3. 2strokeracer
    Crank And/Or Gear up.... OR Setup ?
    Then i would loose bottom end? What one would uz reccomend that would fit straight on?
    Would it be just a secondary gear kit ?
  4. Hursty
    Hursty New Member
    get heavier rollers.
    not a gear up
  5. 2strokeracer
    i was thinking around a 4.5
  6. Hursty
    Hursty New Member
    yeh 4.5 should be good
    ben.
