hi im starting a project speedfight 2 butcrrently it has no spark im replacing the wiring loom as soon as it comes also the coil pack and i wanted to give the stator a clean / sand it down with some sound paper but cant remove it does anyone no how to remove it without using an impact ratchet cheers!
lock the variator then undo the bolt with a normal ratchet. iv then got a flywheel extractor if you want to buy it? never been used.
cheers for that ill try it tomoz i dont think ill need you flywheel remover but if i ever need 1 ill contact you cheers for the advice
it didnt fit my flywheel but mine is aparently different to other peugeot flywheels and was not listed on the list of bikes it would fit. but i thought it was worth a try
