Right i put a thread on here some time ago about my bike playing up yamaha aerox , fully tunned ect. Any way i have now narrowed it down to electics , why this is because of when you disconnect either red/yellow , or the white wire on the stator plate the bikes runs fine. But once both are connected the bike jutters low end then kicks in .Ive tryed the spark looks like its not weaker the spark. Ive tryed cdi stator plate The battery is charging so the reg ect is doing its job. Need this fixed as the m.o.t needs doing . Also my horn dosnt work , its a new horn and switch , any way to test the problem , i have a multi meter . :cheers: :good:
Yes true but no i have the wright stator plate . Pobly just going to get a new loom , as myn is a medd tbh . Then that should fix it i think.
Well ive changed coil cdi stator plate fuse , so its just got to be the loom , maybe a wire is burnt out but i surpose it would be easy to buy a second hand wiring loom, for £15 -20 . Any one else had this problem or know what it could be . many thanks :cheers:
