Starting problems :(
Discussion in 'The Workshop' started by Dexter123, May 17, 2011.
  1. Dexter123
    Dexter123 New Member
    Hi there
    Ive got a new 21mm carb on my peuegot with a ram air filter and its a bitch to start
    doesnt wanna know in the morning, takes about 10 mins to get it going, any ideas on what this problem could be? the slide in the carb is not all the way to the bottom i dunno if that effects it ?
    Any ideas would be greatly appreciated
    Thanks
  2. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    usually the 21mm carbs have a manual choke make sure your using this as it will help it start, if your already doing this i would recommend you try jetting the carb to your scooter maybe have a mess around with your airmixture screw.
  3. Dexter123
    Yeah i have played with the mixture screw, i might just scrap the shitty air filter are they do is make noise lol. im using premix and yeah the choke doesnt really seem to work. i might try jetting the carb up as i have the filter and a leo vince tt so i will play with that when i can as im on crutches Lol
    thanks mate
  4. brettfield999
    brettfield999 Member
    Typhoon 172
    You say that the choke doesnt seem to work. Your 21mm carb is a dellorto one isnt it? If you have the cable choke, ditch it and get a pull choke from your local scooter place like in the link below. I went through 2 cables before i changed it on my old NRG. I have just bought a new 25mm carb for my Typhoon and got rid of the nasty cable choke that comes with it and bought a flip up one.
    http://scooterbits.co.uk/product/Tn..._Carb_Supplied_With_Both_Pull_Or_Cable_Choke/
  5. Dexter123
    yeah pull choke does look alot better will have to purchase one of them bad boys :)
    cheers bud
