Starter motor (i think)
Discussion in 'The Workshop' started by haugh, Aug 19, 2007.
  1. haugh
    haugh New Member
    My bike decides to start one day and sometimes it doesn't start using electric start
    IS this the starter motor?
    If so i think i need a new one :nerd: i heard they are quite expensive to replace :(
    Where could i get one and are they easy to fit?
    Thanks
  2. wobbly_trials
    depends on what it's doing. could be relay, pinion, motor, switch, earth, battery etc...
  3. Jamie
    i had the same problem,the starter, with my indicators + horn aswell, all it needed was a new battery
  4. haugh
    haugh New Member
    indicators and lights are fine just wont start on electric :(
    Could it be spark plug by any chance?
    Will leaving it idle for a while give the battery a charge or am i better of buying a charger?
  5. BrummyBoy
    BrummyBoy New Member
    leaving it on idle wont charge the battery, you have to be doing a certain amount of revs to charge it, on my vx i believe you have to be doing over 2500 revs to charge
  6. capri dave
    capri dave Active Member
    when you say it sometimes doesnt work...is it just silent...starter not trying to turn the engine at all??
    if so it sounds like a dodgy earth!!!
    And starters arent that expensive....ive seen new ones on E-bay for about a tenner!!
  7. wobbly_trials
    actually, when not using the electrics it will charge the battery at tickover, not very quickly though, it won't reach optimum output til 4000-5000 RPM
  8. haugh
    haugh New Member
    U can hear it trying to start but it sounds like its dying :(
    The noise is coming from the back left side somewhere
  9. Jamie
    thats the battery mate. mine sounded identical, basicaly when there isnt enough charge in the battery, the starter motor doesent have enough energy to engage , so just spins until it runs out of power, pick up a new battery cheap from halfords or somethin.
  10. haugh
    haugh New Member
    Cheers :)
