standard 125/180 ports
Discussion in 'Maxiscooter Tuning' started by shiny red, Jan 28, 2009.
  1. shiny red
    shiny red New Member
    anyone know the standard 125/180 exhaust /transfer port distance from TDC :msn1: not got a standard barrel to measure
  2. Blue dwarf
    Blue dwarf New Member
    Exhaust is 34mm down from the top of the cylinder (not tdc of the piston as there`s a difference).
    I`ll do a port map for you tomorrow.
  3. shiny red
    thanks bud :D
  4. seanwhite06
    seanwhite06 New Member
    runner 172, zx6r
    125 barrel,
    34, exhaust
    43, prim transfer
    43 secondary transfer
    and 44 boost
    from top of barrell mind
    deck 0.7 on the one i ported.
    if you want one shiny ive got about 5 lieing around, i can bring one up for ya next time i come round! ;)
  5. shiny red
    cheers sean :punk: where this barrel hiding then get some pics up :wtf:
  6. shiny red
    found in a manual transfers (this is TDC) 42MM
    and zhaust (TDC) 30MM
  7. CU*TSPEED
    CU*TSPEED New Member
    is the 180 barel similer to the 172 or is it way off shiney?
  8. shiny red
    125/180 are the same just bigger bore but as to the ports zhaust is lower and transfers but i need one really to see :D
  9. monty9120
    monty9120 Active Member
    Vespa gts300
    Ive got a 125 barrel i can chuck in the post if it helps?
  10. shiny red
    dont want to seem greedy but i need the piston as well :punk:
  11. WOLFFY
    WOLFFY New Member
    I have a 180 barrel an piston you can have. But I've attacked it with a dremel :w00t:
  12. shiny red
    cheers wolffy but i need the ports intact :beer:
  13. WOLFFY
    WOLFFY New Member
    LOL okay :( :( :( :(
    Only one I touched was zaust port. :( :( :( :( :(
  14. monty9120
    Vespa gts300
    Will have a look fella :cool:
