stalling problems
Discussion in 'The Workshop' started by BrummyBoy, Oct 18, 2007.
  1. BrummyBoy
    BrummyBoy New Member
    The past few days my bike has started to stall, it is only when the engine is warm and ive been riding for 5-10 mins, it seems to cough a little first then completely goes! I can always re start the bike straight away so im not sure what the problem is. Im hopefully going to being seeing Capri Dave this weekend who very nicely said he would clean out my carb for me as he believes this may be the problem.
    The bike is a Runner vx125 so if any one has had/got this problem as well do you have an idea of what it is.
    The stalling obviousely persists until the engine is completely cold
    Can anyone help :(
  2. wobbly_trials
    get your valve clearances checked, sounds like you've got either atight exhaust valve or a tight inlet valve.
  3. monty9120
    monty9120 Active Member
    Vespa gts300
    check valves clean air filter to help it breathe easier
  4. Major Rel14b1lty
    Major Rel14b1lty New Member
    if u got a spare try another spark plug maybe?
  5. alexsr70
    alexsr70 New Member
    if you got a haynes guide then;
    set valve clearances,
    check spark,
    clean carb,
    make sure everythings tight
    tbh it sounds like valves to me
  6. wasman
    wasman New Member
    Always start with the simple fix, spark plug first, then maybe carb clean, check for damp electrics etc, if none of them, delve deeper
  7. BrummyBoy
    its got to be the valves for definite, because its just had a service, ht leads checked, new plug and so on, ive got a haynes manual but im not gonna try it myself.
    Is it an easy job for a dealer to do because ive spent enough on this bike this month :rtfm:
  8. wobbly_trials
    valve clearances should be a service item
  9. alexsr70
    alexsr70 New Member
    thats what i was thinking but you never know so if you checked everything else than that could be it
  10. J-Nitro
    J-Nitro Active Member
    sounds like carbon build up on the valves
  11. BrummyBoy
    just taken the bike in to get fixed, ive told them if anything needs doing along the way just do it!!!!!
  12. wobbly_trials
    ouch, that sounds expensive
  13. MURKEE
    MURKEE New Member
    had similiar prob on my VX
    but it was my idle screw
  14. monty9120
    Vespa gts300
    nope you masked the problem thats all :pimp:
    valves need doing they dont take long dude
  15. MURKEE
    MURKEE New Member
    valves on the 180 piston head goin in soon
    so no biggie
  16. BrummyBoy
    i managed to phone the shop this afternoon thinking the worst but someone seems to be looking after me, cos they are gonna charge me a whole 20 quid!!!! Basically a screw was missing from the choke, and the spark plug cap was mangled, so they have charged me for half hours labour and a new cap and choke screw!! So i get my bike back tomorrow and im a happy boy once again
