Stage6 pro replica
Discussion in 'Scooter Tuning' started by White aerox, Jan 22, 2008.
  1. White aerox
    White aerox New Member
    Hi i carnt find anything on the stage6 pro replica exhaust i am thinking of buying one do you no if these exhausts r any good at all, and with a malossi 70 kit thanks
  2. 2strokeracer
    2strokeracer New Member
    It wont be any better than a laser x pro.
    BTW: Try go down in your roller weights for acceleration.
  3. MiNoR cOnFuSiOn
    BTW: you listen to too many idiots and dont read enough.. rollers only sort accel.. whats stopping me putting 1g rollers in myt bike?
    right. the pro rep aint a bad pipe.. needs verry light rollers as its quite a peaky pipe.. not then best on a sport but work better on an mhr rep.. better pipes for that tho so dont see the point.
    with an iron it will rev a little too high for the power when setup right so you have to roller it down. works really well with a slightly modded exhaust port tho
  4. White aerox
    i dont listen to the idiots i am keeping my rollers the same size it seems revy now anywyas and for the exhaust how do i mod the exhaust port mate
  5. White aerox
    the stage6 exhaust does it come with the gasket and everything
  6. neosman
    neosman Member
    yeah my one did, no rollers though. I had 5 grams in my neos and that was with a polini 70 iron
  7. MiNoR cOnFuSiOn
    widen the exhaust n match the barrel.. not as easy as it sounds but giving it a go wont hurt.. just stay away from the inner part of the exhaust port.
