stage 6 sport pro small end bearing
Discussion in 'The Workshop' started by billy #86, Jan 17, 2009.
  1. billy #86
    billy #86 New Member
    ive recently bought a new piston for my s6 sport pro 70 kit and it had gudgeon pin for a 10mm bearing but the piston ive got for it now has a gudgeon pin for an 8mm bearing. so does anyone know anywhere online where i can get an 8mm small end bearing for an aerox??
    cheers
  2. Blue dwarf
    Blue dwarf New Member
    Simple answer is you cant.
    Aerox`s have a 10mm little end unless it`s fitted with an evo or similar crank that takes a 12mm little end.
    If you have a std crank or even a std replacement performance crank as opposed to an evo etc it`ll have a 10mm little end.
    Some high-end kits use a 12mm little end for strength so they have to be fitted on such a crank.
  3. billy #86
    ive just checked both with the vernier and it turns out the gudgeon pin is 10mm :emb: but i bought this of:
    http://donotlink-pedstop.co.uk/p/1-X-SM ... -1711.aspx
    whih says its for a 10mm pin but the inside di of the bearing is 12mm so have they sent me the bearings for a 12mm pin then??
    thanks
  4. billy #86
    ive also just checked the crank and the inner di is around 15mm and takes the 12mm bearing and pin,
    ive just realised you can get a 12mm s6 sport pro 70 kit so this is what the previous owner must of fitted along with a 12mm crank, so ive got a spare new 10mm piston :w00t:,
