ok i got my stage 6 sport pro cylinder but i cant work out where a couple of the black rings you get with it go and i got 4 red rings that i cant work out where they go either could any help me i got a picture to help.
maybe this is just how they box them like every kit goes out with the same gaskets so a kit with a 2 part cylinder head will need the 8 little o rings but yours only needs 4 hmm the black ring is the thermostat on the outside, put it around the outside of the head and screw the thermostat in to seal it the plug is protected by the middle sized o ring in the middle of the 4 orange little ones is the remaining ring rubber? the black one?
does the head come out of the jacket or is that all one peice of metal? if it comes apart there will eb a bakc seal between the 2 bits where the plug goes and on one the thermostat fitting, then one on the studs between the two sections.
