Hi all, I have a jog rr with a sport pro mk2 kit and a stage 6 pro rep pipe fitted. Anyone know what the power band should be for this setup? Roughly what weight rollers will be suitable? Thanks
I’ve just built a midrace engine on a gilera it’s running a Mallosi multivar with 5.5 g rollers and it’s spot on... hope that helps
Surely each kit/ exhaust combination makes peak power at a certain rpm? How will I know what this is? Ped parts dyno charts are a little confusing as on one bike the kit/exhaust is making peak power at 9500rpm, but then on another graph and different bike it is 11500rpm....?
What is your reason for wanting to know? The idea with a 2stroke auto is to have the power band sweet spot across the whole revs.... we acheive this with a well balanced varitaor
No sorry should have said. Setup is as follows: Stage 6 sport pro mk2 Stage 6 pro rep pipe Full circle updated crank shaft Stage 6 variator with 5g rollers that come with it Updated reed block Unrestricted inlet Stage 6 clutch 17.5mm carb
