Hi guys looking to buy a stage 6 hpc crankshaft tomorow just wondering do i need anything else apart from C4 bearings and seals Also do i get 10mm or 12mm bearing one ????
You should just need the bearings. I would go for a 12mm pin, you can get an oversized small end bearing that will allow you to use a 10mm pin piston too. So with a 12mm you can use any cylinder really.
Oh so a 12 will be beter then realy i wont have to buy anything extra with the 12 mm one and it will go straight in ? Im buyin a s6 streetrace kit aswel will the 12mm make any differnce ?
Probaly be better just to get the 10mm one then realy cuz i wont be changing cylinders tbf wT do you think ?
