sr50r slow project
Discussion in 'Scooter Projects' started by BAMFORD#139, Sep 23, 2009.
  1. BAMFORD#139
    BAMFORD#139 New Member
    APRILIA SR50 FACTORY
    well here is my sr50r 05 plate asit stands :)
    bought the gianelli of INO for 20 smackers it looked like this
    then a lil while later
    then after abit of a struggle and a shortage of bolts i got it on the bike
    plans for it are new crankshaft on tomoro with malossi variator n white contra n obv upjet.
    get some money and a shiny red lightened flywheel...air filter, then clutch springs..
    qand next week shud be gettin my malossi 70s kit and thinkin bout a bigger carb
  2. INO
    INO Member
    That come up nice. have you got a 17.5 carb? if so i might have a 20.5 carb u can have for free, hopefully will get that crank fitted later
  3. bait
    bait Active Member
    lol lasoo laces
    that pipe dont look half bad after a clean up
  4. INO
    INO Member
    Dont it just im just lazy nice job mate
  5. BAMFORD#139
    Yeah cheers and ino yeah ill have tht carb of you n ill giv you a ring when its done
  6. Sh0x
    Sh0x New Member
    old thread but I just saw your bike
    You should remove the aprilia sticker on the belly panel. Maybe get just white aprilia decal . or try spraying it white (properly)
    Nice SR!
  7. BAMFORD#139
    Yeah cheers fo that and I was thinking the samebwhen I was lookin at it n thinkin to take it off n spray it white or the rim blue colour
    And the bike has been offroad sinse this but is on the brink of running again just need the crank bolts which are a bugger to get on and have no more time because I'm goin away
    And so far I've got pm crank..gianelli pipe..malossi vario..20.5 carb..new clutch springs..5.1 rollers..riser block. And next gettin renthals but need a stem to fit my bike first and mayb a 70s kit
  8. Sh0x
    Sh0x New Member
    Get the bike running before putting aftermarket bits on :p
  9. BAMFORD#139
    Yeah I am the carb isn't on or anything .. just a standard 50 with new crank because other one was worn but everythin else is goin on when its running
