SR50R Keeps dieing out.
Discussion in 'The Workshop' started by gregzzz, Apr 20, 2010.
  1. gregzzz
    gregzzz New Member
    nrg
    http://s42.photobucket.com/albums/e348/Method-Hosting/?action=view&current=MOV00122.flv
    Heres a video,
    i kickstart it fine and it ticks over nicley then after 2 seconds or so it cuts out, even if i don't rev it. So seems like a carb problem, there is also a pool of petrol dripping out the carb. Considering getting a 17.5 carb second hand or a 21mm stage 6 carb so i can use it but i'm not sure if this is the smartest route.
    Saturday i will clean out the jets, wash carb out with petrol, clean airbox, check reeds and inlet.
    Any ideas from the video, cheers.
  2. monty9120
    monty9120 Active Member
    Vespa gts300
    the only way it will piss out petrol is if the float pin has come out
    sounds to me like it needs that sorting first as rthe fuel in the bottom of the carb is being pissed out the bottom of the bike isnt getting alot.
    might need a bigger mainjet as well whats its running. have you checked all the fuel pipes are put in the right places any vacuums to the tank correct
  3. MiNoR cOnFuSiOn
    ether that or theres a massive leak and your fuel tap isnt filling the carb as quickly as the fuel is pissing out..... meaning your not gettign any fuel through the engine.. find WHERE the fuel's comming from, fix this.. will probably cure all the other problems..
