Piaggio sr50 Tehno gas exhaust not sure what model Piaggio NRG 50 Power DT AC 07-09 17.5mm Carburettor with Auto Choke 70cc cast iron cylinder kit from Naraku for Piaggio Aprilia SR50 R 45° 28/35mm Racing Air Filter Red ticks over ok but when reved bogging down tried a 76 main jet bogging down 82 bogging down 92 bogging down 98 bogging down 102 wont run on this jet any idea just wont run on this filter
yes was running better with air box but getting hot do I leave the brass washer in back of carb the one with holes in
Thanks for reply yes original manifold going to try a 80 jet and change crank seals and try orginal filter like you say as seems to be getting hot
Open filter doesnt work on 17,5, if u want to use it get 19mm or 21mm phbg carb. Also remove the restrictor plate with the holes , and modify the airbox inlet diameter to 18mm and then jet it should be 65-85 somewhere.
im going to leave 17.5mm carb on so do you mean to leave brass washer out with holes in it and make inlet hole in air box bigger to 18mm
WASHER OUT, and the intake tube that the AIRBOX takes air from in stock is 12mm i think make it 18mm inside diameter.
