sr180 malossi bore
Discussion in 'Maxiscooter Tuning' started by josh dudley, Apr 17, 2012.
  1. josh dudley
    josh dudley ride it,like u stole it
    Hi there every one i am starting a sr125 project from just the frame.i am getting malossi bore but i cant decide weather it will be worth buying the 180 one instead of a 172 kit.
    And weather it is less relaible and would you have to put different gearing,belt clutch ect.... thanks josh.
  2. ramo
    ramo GoldMember
    Since when do they do a/c 180s?
  3. josh dudley
    I dunno i see it on a website i am sure it is for a sr125 ac i will post a link up mate
  4. josh dudley
  5. ramo
    ramo GoldMember
    If that's a Malossi bore as it says then its deffo just a wrongly described 172. I think it's maybe something to do with 180s being actually a bit less than 180cc and 172s being a bit more than 172cc and Beedspeed being a bit gumtree but im no expert.
    Biggest AC cylinder as far as I know is a 172. I've got an AC 172 and couldn't be happier with it. As reliable as stock in my experience
  6. sr125ni
    sr125ni Member
    When changing to the 172 kit do you need to change the carb or is the stock one good if its up jetted ??
  7. josh dudley
    Beedspeed being a bit gumtree?? what are you on? Lol
  8. josh dudley
    Ramo whats ure bike set up like?
  9. ramo
    ramo GoldMember
    Beedspeed just describing it badly tbh. Theyre a decent company though but you probs can find it a bit cheaper elsewhere
    I've got a 172 with 25mm and a 180 variator and am quite happy with it. I ran mine with stock carb for a while and reckon you defintely feel a difference with a 25mm..in fact I reckon the 25mm made it a bit easier for me to set up
    josh dudley likes this.
  10. josh dudley
    Thanks alot for the advice,i will give it a try
