150? i never knew they made them :$ , what are they like performance wise? have you had a chance to rid this one yet? are you planning on tunning it, or just clean and standard?
I was told they made limited numbers on this 150cc version. I got a quick ride about 10metres? which the bike was in bad shape, stripped down and rebulid again. Yes, tuning it for sure. Waiting to be fix: TM24/malossi reedblock polini variator/pinasco torque spring malossi Gear up kit bitubo shock run pre-mix(oil tank/pump removed) fast throttle koso meter stage6 260mm brake disc malossi straight manifold rear undertray/BGM LED lamp Plans: 180cc stator,rotor and CDI 172 block/BGM crank(Flow/match block + crankcase) Revalve fork TM28 :cheers:
