hello people i was just wondering if you think that this setupo is good? stage 6 sport pro 70kit stage 6 reedblock stage 6 inletmaifold carb upjetted stage 6 midrace airfilter already have doppler endurance crank malossi variator malossi clutch stage 6 roller pack stage 6 pro replica pipe? or a yasuni c20? thanks people if i get good results then ill order it upp
well theres no mention of a carb there so ditch the filter idea n stick with the airbox.. any setup is fine, just match the cylinder to the pipe it requires and do what you like with the rest
ok then so i need to change the inlet mai to get one that you can run with airbox then and ok thanks what pipe out of the 2 would be better?
never used a sport pro rep (how they come up wiht these names i dont know, surely thats an ALI kit, not 3 diff kits all in one ) im sure there are dyno figures on these kits wiht different pipes.. id asume the pro rep exhaust is the best match as its made for it? couldent really say m8.
no.. its just sport, pro and rep are 3 completly different things, all bundeled into one cylinder for no reason... just poor wording and overcomplicated branding of parts.. why not "stage 6 aliminum kit, professional and professional rep" surely it would make more sence than naming everything asif its really really good
