Squish setting
Discussion in 'The Workshop' started by Daniel172, Dec 30, 2007.
  1. Daniel172
    Daniel172 Member
    Hi what should be the squish setting for a runner 172 with a kb billet racing head?? 0.8mm to 1.0mm?? Its got a bgm 52 crank. any answers would be much appreciated :cool:
    Thanks
  2. wobbly_trials
    1mm is a bare minimum really on a 172 running standard petrol.
  3. Daniel172
    Daniel172 Member
    so should it be more than 1mm???
  4. wobbly_trials
    personally i would stick to 1 to 1.4mm (obviously depending on how much i want to squeeze from the engine), there is a topic about 70 squish settings on here, it's the same principal just with a physically bigger engine.
  5. MiNoR cOnFuSiOn
    the heads are higher compression (hope your not running the one for the 54/55 stroke) you need to set the squish verry loose on those on an unported head or you get lots of predetonation.. high comp heads are made to combat the compression lost to a higher exhaust port (ported barrel) with a stock barrel it makes around 12:1 mathmatical compression ratio wich is way too hgih for road fuel so drop the squish to around 1.8/2.2mm. it wont burn correctly at a higher compression.
  6. Daniel172
    Daniel172 Member
  7. wobbly_trials
    i stand corrected. i like 14:1 + though
