sqeaking noise coming from engine area
Discussion in 'Scooter Tuning' started by typh-gilly99, Sep 14, 2009.
  1. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    my cousins ped makes a sqeeking noice when he thottles his zip, it will only last for about 10 mins then after that it goes, any ideas?
  2. MiNoR cOnFuSiOn
    belt is dry/cracked... torque drive could be dry and in need of some grease on the pins.. variator fan could be rubbing on the inside of the kickstart.
  3. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    minor i checked all of the above and the noise still seems to happen....could it be something else?
  4. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    by the way a polini 70cc kit was put in the other day, could it be something to do with this?
  5. gregzzz
    gregzzz New Member
    nrg
    centre stand mine rattles like a mofo might tek it off when i get my side stand
  6. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    i doubt it could be the centre stand because it seems like its coming from the variator area. I changed my rollers the other day but i didnt grease it up again, do you think that could be the problem?
  7. MiNoR cOnFuSiOn
    a LIGHT coating of thin grease wont hurt the variator.. even if they are self lubricating rollers. its wrth a try to see if your roller type is the problem.
    check the waterpump (if it is wc obv) as if it seizes/starts to seize the bearings will ether spin noisy or even worse, seize up and force the drive gear to rotate freely on the pump = no waterpump turning..
    can be a bearing on the imput shaft (one the clutch sits on) so check these, altho if its stationary those bearings wont be spinning, in wich case it could be the clutch bearings themselves...
    just go through every bit by bit,. if theres still a sound wiht everything spinning freely and clean/quiet then change the oil pump. this is all on the basis that the noise actually is comming from the tranny cover
  8. SimonT
    SimonT New Member
    I had this for a while... before a crank bearing failed on me...
    anyone placing bets????
