sprocket
Discussion in 'Bike Chat' started by Purplepill, Jul 24, 2007.
  1. Purplepill
    Purplepill Member
    how can i tell if my sprocket carrier bearing is fucked? apparantly it was replaced at 12k due to drive noise, an im now at 40k so just wanna rule that out as the drive noise iv got.
  2. morgan
    morgan Member
    try to move it around and a clockwise/anticlockwise movement, like twist it on way then the other, if it has lots of play the carrier might be knackered.
  3. Purplepill
    Purplepill Member
    cheers for that, also how many hours labour do you rekon a garage will charge to change steering head bearing set (top and bottom?) :pimp:
  4. morgan
    morgan Member
    If you help them out by removing fairings etc nefore you take it, you can cut down the labour by a fair bit, i reckon about 1-2 hours labour to change what you want done.
  5. Purplepill
    Purplepill Member
    nuts was hopeing it'd take less than an hour :( cheers
  6. morgan
    morgan Member
    bring them to me i'll do it for less :p
    BTW FYI im SM.Morgan on BCF
