spraying rims
Discussion in 'General Scooter Discussion' started by rideorcollide, Mar 26, 2008.
  1. rideorcollide
    rideorcollide Active Member
    TYPH 172
    i want to spray my rims but getting my tires off to do it is kinda loong, so i was wondering if anyone has done it with the tires on and taped over them.
    or is it possible to take my tires off myself and do it.
  2. chris14
    chris14 New Member
    iv dun a few sets for m8s now
    what i do is let the tyres down so makes it easyer to put tape around the edge
    works fine and u cant tell if u have or havnt taken the tyres of when the tyres are pumped back up
  3. numanoid1704
    numanoid1704 New Member
    tyres
    ive used a similar trick,let the tyres down then put cardboard between the tyre and the rim(breakfast cereal box type)fill in any little gaps with masking tape. then spray away :D bit of a short cut but it works :D
  4. chris14
    chris14 New Member
    yh that would work but if you use masking tape you can paint both sides at the same time
  5. numanoid1704
    rims
    just mask with newspaper at top of cardboard :D
  6. chris14
    chris14 New Member
    true both ways are good
  7. rideorcollide
    TYPH 172
    yh that sounds pretty good. kl for that guys
  8. superped
    superped New Member
    italjet dragster 172
    best way to do this ( i have done alot of rims ) is to let the tire flat fold it over to one side masking tape it down then spray trust me its the best way :w00t:
