spluttering then died? HELP!
Discussion in 'The Workshop' started by zipSP70, Sep 2, 2010.
  1. zipSP70
    zipSP70 Member
    Piaggio Zip SP 70
    i have a problem with my zip sp
    it just started caughing and spluttering then a couple of miles later it died. a few minutes later i tried to start it again which it did but died about 3 seconds after.
    i checked the plug which was fine (running slightly rich) and carb. the carb needle was out of place which i thaught was the problem but wasnt.
    i filled it up with petrol a few minutes before it started to splutter, maybe its a fuel issue? and no i DIDNT put diesel in it haa. the new 70 kit has only done around 100 miles.
    i used jump leads on a car to try and start it due to the flat battery but now when i go to start it the starter motor goes into hyper mode!
    any help appreciated
  2. capri dave
    capri dave Active Member
    you need to check you have plenty of compression, you have a spark, there is fuel getting to the engine and finally there is air...those are the main ingredients of a running engine...
  3. zipSP70
    zipSP70 Member
    Piaggio Zip SP 70
    yeah checked all them, its fine
    time to take the top end off i think...
  4. zipSP70
    zipSP70 Member
    Piaggio Zip SP 70
    found out the problem
    the crank has gone. Big eng totally disintigrated.
    so just installed a Athena HPC full circle one.
