Split open the crank casing
Discussion in 'The Workshop' started by RIGZ.172, May 8, 2011.
  1. RIGZ.172
    RIGZ.172 Member
    camel
    Hi all i have a dna 50 which the engine sounds like a truck i have a strong feeling that my crank bearings are about to go can anybody help me on what i have to do to split open my crank casing.
    Thank you
  2. northrider
    northrider Member
    its long to explain if you search youll find some older post where its been explained step by step
  3. nathan93
    Gilera Ice
    1- remove the engine and the stand from the engine
    2- remove everything from the crank, remove the inlet manifold and the cylinder
    3- undo the bolts that hold the 2 halfs together, undoing the oposite bolt to the 1 you started on each time, use an 8mm 6point socket
    4- then if your replacing the crank use a rubber hammer and hit the end of the crank while lifting the flywheel side of the casing and eventually the crank should leave the bearing and come free, repeat on the other side of the case and hammer out the crank from that side
    hope that helps, might not be 100% accurate
  4. wobbly_trials
    splitting the engine is a fairly in depth exercise, i would suggest you find someone who can take you through it step by step for your first attempt, scooter engines are built to quite fine tolerances and so have to be rebuilt with a certain ammount of attention to detail. it's worth having someone just to say if you get anything not quite right.
    also use some heat around the bearings to help release them from the cases. removal of bearings from the crank can be a real nightmare, i tend to cut them off with a small grinder, although doing this always leaves a small risk of catching the crank and you have to clean it out throughly afterwards.
  5. RIGZ.172
    RIGZ.172 Member
    camel
    thank you for your help wobbly i am confident of splitting it open the thing that i know for sure im gonna get stuck on is trynna remove the bearings from the casings quick question if crank bearings are on there way how long do they last up to?
