Hii i have a 53 speedy 2 L/C and everything was fine with it getting 52 clock speed , but suddenly today when i went out on it i could only get 45 when i have it full throttle or it would sometimes get to 52 if i released the throttle and then opened it fully again but would take way way longer then usual .. i though it could have been the zaust so ive re-packed the end can and cleaned out the main pipe with costic soda but still i have the same problem .. anyone no what it could be ? John
Rollers = fine Cleaned air filer and compartment out with petrol . Jet = fine Cleaned out carb bowl Put new spark plug in Still not fixed the problem
sounds like general wear and tear to the transmission to me stick a new belt in and ee what its saying...
Tryed a new belt and no difference Do you think it could be my engine ? Like it needs de-cokeing / new piston rings putting it ? John
check tires, badly pressured tires can easily kill 5mph off top speed. one thing you may need to remember is that you should never clean an air filter with petrol, use warm water and and a detergant of sum sort then apply air filter oil to it.
i use warm water and washing up liquid my runner is an 02 model and still has the original sponge air filter element it left the factory with.... i just wash it a couple of times a year
