speedy problem had it ages
Discussion in 'The Workshop' started by kylespeedfight, Mar 30, 2011.
  1. kylespeedfight
    kylespeedfight Active Member
    New Gilera Runner 70
    Replaced engine, piston, head and barrel, crank seals, carb, reed valve, all gaskets and still does the same thing. Anyone have a clue at all im out of ideas :confused:cratch: Thanks
  2. kylespeedfight
    it runs on half rev but all it does is splutter then blow air out exhaust which kills it
  3. MattWadz
    MattWadz Member
    Piaggio Zip RST 50
    if youve replaced all of the stuff you said above, then its definetly a wiring fault, check the loom and replace it
  4. kylespeedfight
    there is a wire unplugged but im sure its for an alarm, just a single red and black cable with a bullet connector, i never had this on my other engine
  5. MattWadz
    MattWadz Member
    Piaggio Zip RST 50
    hmm, i doubt that would be it have you changed the CDI? id definetly try that
  6. kylespeedfight
    not got the money but my cdi should be fine, worked before i ceased my engine and just bolted another straight in and it wont work.
  7. kylespeedfight
    aparrently needs a new piston again :? looks brand new to me apart from it has one good ring and one bad ring on it, the top ring is new and the bottom is old and worn, ( damaged a ring by accident) barrel is lightly scored but should still run. Any ideas as wiring is all fine and cdi is fine?
  8. Gamble
    Gamble Member
    Not saying it's necessarily the primary cause, however I'd re-ring it anyway as you know it's not right.
