Basically the speed displays 0 until I go faster than 30mph & goes back to 0 if I go back under 30mph, what is causing this? I have a standard 2013 125cc Gilera Runner
Check the inside of the speedo drive on the front wheel. There should be two 'tangs' that engage with the wheel cut outs. If you only have one tang in the drive it can cause this problem. Only solution is a new drive.
