Yes all connected but we left it on wen we did throttle a while back and now it won't work but spinning the front wheel nothing
I have tryed to take the cable out the speedo but won't come out If I would to buy a digi one how would I set up the speec and rev
un-screw it from the drive on the front wheel, make sure it is pushed all the way up towards the speedo housing and spin the end of the cable in your fingers while watching the needle. If it aint broke it will move the needle some; if it is broke it will come out in your hand in two pieces.
Ok thanks ill have alook as looks like I won't be riding now till end of feb or end of march as money for some reason come tight so I may strip rebuild engine and put some mods or may sell it buy summit eles would like a zip 125 or typhoon or runner or sr
If the cable can be undone at the wheel end, put the inner cable in the chuck of a drill and give it a spin (make sure that the drill spins the right way). If the clock doesn't move then either the cable has broken inside or the clock is knackered.
