Speedo drives
Discussion in 'The Workshop' started by PDBV, Oct 8, 2013.
  1. PDBV
    PDBV Member
    Are the drive mechanisms between the wheel and the speedo drive unit the same for all 50cc scoots ?
    I have typhoon forks on my mc2 now and need to get the typhoon speedo drive as the locating lug is different but i dont know if i will nee to get the wheel as well :/
    Any help much appreciated :)
    Sent from my GT-N7100 using Tapatalk 4
  2. ziggy_tph125
    ziggy_tph125 SONIC BOOOOM!!
    Piaggio Typoon 125,
    i do know the typhoon has two different necks on the drive mechanism that the speedo cable goes on to because you get a long and short speedo cable, i had a long neck and a short cable so the cable never reached into the drive, so i got the long cable and it all worked fine, im defo that there are two different drives but not sure if one is for 50z an one is for 125z, hope that helps abit but im sure somone will have a defanate answer for u soon.
  3. PDBV
    PDBV Member
    Cheers pal :)
  4. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    If the rolling radius of the wheel and tyre hasn't changed, then your speedo should still read the same with the new drive connected.
