speedo drive
Discussion in 'The Workshop' started by 125TypHXR, Apr 10, 2010.
  1. 125TypHXR
    125TypHXR Member
    if u use a runner front wheel , with a storm disk do i need to change the speedo drive. :confused:cratch:
  2. adz452
    adz452 Member
    Vespa T5
    the disk is on the opposite side of the wheel??
  3. 125TypHXR
    125TypHXR Member
    lol obv , if i use a runner wheel on typh forks do i need to change the speedo drive?
  4. MiNoR cOnFuSiOn
    if your using a 50 wheel then no, if its a 125 wheel (speedo part on the wheel is 2 sticky out bits) then you need to cut a part off the outside of the drive so it fits in the typh forks....
    if its the storm/50 type speedo drive (little tab go's into one hole in thwe wheel) then it fits into typh forks... just look at the 2 you have, will soon see if there different. ether way you can mod the correct one to fit fairly easily
  5. 125TypHXR
    125TypHXR Member
    its a 180 sp front wheel 1997/1998 model.
  6. 125TypHXR
    125TypHXR Member
    its a 180 sp front wheel 1997/1998 model. it has 2 bits sticking out.
  7. MiNoR cOnFuSiOn
    then your gonna have to mod the speedo drive from that wheel to go into the typh forks... just look at the typh drive, there is a step in it... put this step in the runner drive and remove the 2 original locating lugs... will all bolt together perfect.
  8. 125TypHXR
    125TypHXR Member
    thanks for info minor , but could i use the correct speedo drive without modding or would i still have to mod the runner drive to fit on typh forks.thanks
  9. MiNoR cOnFuSiOn
    the speedo drive is dependant on what type of wheel you use, you cant use the wrong speedo drive for your wheel... but you can mod the wrong speedo drive to fit the forks you have.
    use the drive from the wheel your using basicly and mod the rest to match the forks
