Hi can anyone out there guide me,should the immobilzer light still flash when the ignition key is in the start posistion,Mine does and the bike wont start.the starter motor is turning over ,The battery has lost all its charge while the bike was just sat there for 4 days.I have charged it and now the lights dont work either.has it blown a fuse some where.any advice would be welcome. :banghead:
when the key is in the start position the light goes off/stops flashing, lights wont work unless the engine is running they draw power from the engine not the battery, sounds like there is something wrong with your immobiliser, you can get a bypass that you plug in but there not cheap, its a common problem with speedfight immobilisers, before trying anything you should reprogramme the key, dont know how to do it ask a local dealer or search it on google hope this helps
