Speedfight very boggy and slow
Discussion in 'The Workshop' started by Brooker_speedfight2, Nov 12, 2011.
  1. Brooker_speedfight2
    Brooker_speedfight2 Member
    Peugeot SpeedFight 2
    Hi all,i have a peugeot speedfight 2, it is all standard apart from the rollers. I dont expect it to be fast as it is standard but it does seem very slow especially when its cold. Sometimes setting off it will be quick and get up to speed, but most of the time it seems very boggy and as if something is slipping, possibly need new clutch shoes ? Also, its using a hell of a lot of petrol !
    Any help will me much appreciated !
  2. Anton Kash
    Anton Kash Member
    Typh
    It might be your jet. Have a look at what size jet you got.
  3. TeZ258
    TeZ258 Member
    Speedfight 50cc
    What weight rollers do you have in also ?
  4. Brooker_speedfight2
    Im not sure what weight rollers as i didnt do them haha. Getting a racing exhaust and clutch springs in a week or so
  5. Jonnymarrw00t
    Piaggio Zip 05 plate
    Well take them out and weigh them and devide it by 6.... What exhaust you buying ? It could be your choke. Also check what jet you're running.
  6. Brooker_speedfight2
    Im gonna take the air filter and carb off today and give it all a good clean. any tips for cleaning the jet ? And is it easy enough to get the carb n everythin out and back together? I used to be a car mechanic but never really worked on bikes
  7. Brooker_speedfight2
    Just been out on it this morning, i think it needs a new belt and clutch shoes as it feels as if something is slipping. Going up hill it just dies if u put more than quarter throttle, and its using ALOT of petrol but there is no leaks :( Iv took air filter off and give it a clean but no help
  8. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    if its going to die thats not ur clutch, its ur fuel mixture.
  9. Brooker_speedfight2
    Can i adjust the mixture on the carb? Correct me if im wrong but im sure you can adjust it using a screw driver
  10. Jonnymarrw00t
    No that's the idle. Jet has to be changed.
  11. xplicit vehicle
    PGO Big Max 50
    ^ what he said
  12. oliwest
    oliwest Member
    aerox road legal pit
    mines sort of doing the same mate, will be fuel and/or air settings :)
  13. Brooker_speedfight2
    Iv had a look at the carb, and the fuel and air screw has one of them temper proof things there instead :( iv managed twist it slightly though
  14. Jonnymarrw00t
    :/ what carb you got.... ? Mine aint like that. I got a 12mm gutner.
  15. Brooker_speedfight2
    Standard factory carb, like i said the only modifications it has are upgraded rollers.
  16. Jonnymarrw00t
    It can't be? I have standard speedfight carb it had all the skrews on it.... WHy have you upgraded the rollers ?
  17. Brooker_speedfight2
    They were already upgraded when i got it, and the fuel and air screw is a tamper proof screw, im just gonna buy a new carb lol
  18. Jonnymarrw00t
    Go for a 17.5mm and buy a carb adapter from Pedparts. Will run better. Find out what weight your rollers are. If they're too light they wont work properly.
    Sadders69 likes this.
  19. Brooker_speedfight2
    I will do when i get paid haha. My mate has a speedfight 3 and its rapid ! well compared to mine it is haha i struggle getting past 25 !
  20. Jonnymarrw00t
    You sure it's fully de-restricted :/?
