speedfight rollers
Discussion in 'Newbie Scooter Tuning' started by jackzip, Jul 27, 2010.
  1. jackzip
    jackzip New Member
    need suggestion what weight rollers shall i put on my speedfight 100 and should i put stiffer clutch spring in too ?
  2. tErr0
    If it's stock you leave it stock... Simple.
  3. russell
    russell New Member
    standards
  4. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    i think standerd rollers are 5.5 gram but you should not change these unless you have put some performance parts on. stronger clutch springs will make it take off at a higher rev giving you beta acceleration unless you have an exhaust or other parts you should not reli need these
  5. capri dave
    capri dave Active Member
    im pretty sure from distant memory that speedfight rollers are a lot heavier than 5.5 grams :glare:
    think its more about 8 grams ;)
  6. GUNS
    GUNS the usual suspect
    racing SP70 & LX172
    the guide has then as follows;
    SPEEDFIGHT 100cc 19x13.5 8.8
    SPEEDFIGHT 2 100cc 18x14 12.8
