Speedfight Problems
Discussion in 'The Workshop' started by TeZ258, Nov 25, 2010.
  1. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Hi all,
    Ive had my Speedfight 50 for around 7 months.
    Current setup is:
    Doppler S3R exhaust with rollers and jetting to suit
    Polini Variator
    Polini evo clutch.
    The problem is that when I take off it 'under revs' and really struggles upto about 20mph clock speed and then is suddenly fine.
    Also the top speed is pants ! On my old Gianelli Extra it used to reach around about 50mph clock speed. Now it only does like 43mph.
    So far ive checked:
    Rollers- there fine
    Jetting- Spark plug is tanned.
    Variator ramps- fine
    Clutch- Good
    Belt- Dunno
    Feels like somethings slipping but ive tried everything to do with the transmission. When its on the stand it struggles to initially rev up, 'juddders' a few times then its fine.
    Cant make sense of it at all.
    EDIT: The variator was second hand and didnt come with any 'shims'
  2. capri dave
    capri dave Active Member
    if the throttle response is bad when on the stand, then that would suggest to me its a carb problem...
    also...was your transmission set up with the extra, and your problems started when you fitted the Doppler pipe??
    The Doppler S3R is a very revvy pipe, and doesnt have the low down torque of the giannelli extra, so you will more than likely need lighter rollers and more tension on your clutch springs...
  3. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Well ive put the rollers that came with the doppler in.
    It does sound like carburation but ive tried everything jets, needle positions, gaskets, air filters, cleaning and checked everything to do with the float.
  4. capri dave
    I would of thought it would be a simple mixture screw issue myself.
  5. capri dave
    also i forgot to say, dont take what rollers you get with a pipe as gospel...
  6. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Ha same here.
    Everytime im out i have to pull over to try a different mixture screw position.
    For the record its fine when its running just after coming off choke.
    And i know. I have some 5.3s spare
  7. capri dave
    mixture too rich maybe, a cool engine will tolerate a rich mixture better than a hot engine :glare:
  8. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Oki.
    Might slap my open air filter on tomorrow. Getting a Polini sports kit soon so there no point spending money on jets when they wont be used again.
  9. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Right ive uploaded a vid showing the transmission.
    Any suggestions on what is going on would be appreciated.
    Tried everything everyone has suggested. This is just to show what exactly is going on down in the transmission area.
    Thank You.
  10. capri dave
    your idle is very lumpy, your mixture isnt set properly :glare:
  11. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Oki dokie.
    Will have a look.
    Also I noticed that the belt seemed 'loose' as well. You can see it on the video.
    Ta Dave.
  12. capri dave
    they all flap around a bit when they are running....its normal :)
  13. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Oki dokie.
    Just find it strange that it wobbles like that.
    When I bought the variator(polini) it didn't come with any washers/spacers as shown in the pics of it.
    I think a new variator and belt is in order.
  14. capri dave
    The belts do tend to be stiffer when they are new, and go softer once worn...
  15. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Right this is my spark plug after i changed the throttle needle to the top notch. ( was on the bottom notch for some strange reason, hence the reason for the awful idle)
    Take off is really strong now. But top speed and mid range acceleration isnt very good.
    Is it running lean now? Or is it something else.
  16. monty9120
    monty9120 Active Member
    Vespa gts300
    thats well lean either put the airbox back on or you need to upjet.
  17. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Lol. Ill do it tomorrow.
    Thanks :D
