speedfight is at it again
Discussion in 'General Scooter Discussion' started by Cockers, Mar 22, 2013.
  1. Cockers
    Cockers I hate speedfights
    Just had new carb new choke nee plug and coil and refusing to start from cold battery is flat and i can't kick it over any ideas
    It was good yesterday starting straight away riding nice and out hesitated once last night in cold and now it won't start
  2. Cockers
    I can smell it bring flooded so that leads me to believe a spark problem
  3. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Check it's sparking first. Why can't you use the kickstart?
  4. Cockers
    Got nice juicy spark. I'm editing on a kick start pinion
  5. lee mason
    lee mason Active Member
    suzuki rg125 gamma
    have you got the new carb set up properly
  6. steveaerox50
    steveaerox50 aprilia owner
    1999 aprilia rs125
    if you smell it getting flooded the main jet is to big , or the choke as been left on or is sticking , or the float is sticking :)
  7. Cockers
    it was while to choke was on so I'm thinking it was that!
    Will down jet to 92 if need be!
    got spark, compression all of that.
    I've flattened my battery but its on charge now will give the mixture a tweak see if i have any joy.
    cheers
  8. steveaerox50
    1999 aprilia rs125
    yeah sounds like you left the choke on for to long and flooded it lol
  9. TeZ258
    TeZ258 Member
    Speedfight 50cc
    When mine wouldn't start the other day I adjusted the mixture screw and turned the idle screw further in and it started first or second kick.
  10. Cockers
    will give it a try when battery has charged abit I'm sick my kick start would stop working at this time! I ordered a new pinion on the 18th and it aint arrived yet and nothing ped parts can do unless it has been 15 days if it is lost!
  11. Cockers
    got it sorted running I either need to mess with the mixture or re jet, it started when the mixture screw was nearly all the way out so does that mean I've got the wrong jet in? It splutters abit pulling away sometimes so is that a down jet? cheers
  12. steveaerox50
    1999 aprilia rs125
    if its spluttering its running to rich mate , knock the main jet down a bit and try it
  13. Cockers
    I think its a spluttering, it used to do it with the other carb when i pull away it will take the revs a few seconds to pic up then its fine, I'll knock the main jet down back to 92 see what difference it makes cheers
  14. steveaerox50
    1999 aprilia rs125
    is it full throttle when it does it ?
  15. Cockers
    yeah it is only when I full throttle it!
  16. steveaerox50
    1999 aprilia rs125
    yeah its the main jet then mate
  17. Cockers
    cheers mate will go try it
    you're me hero haha!
  18. steveaerox50
    1999 aprilia rs125
    haha let us no how you go on fella
  19. Cockers
    jetted down to 95 I think it was seems alright revs still take a few seconds to pick up at full throttle but it alright at half throttle.
    Will look into it tomorrow or something got work in an hour and its to cold and windy to be messing about haha
  20. steveaerox50
    1999 aprilia rs125
    ok mate sound
