Speedfight engine
Discussion in 'For Sale' started by Major Rel14b1lty, Oct 22, 2007.
  1. Major Rel14b1lty
    Major Rel14b1lty New Member
    Speedfight engine just had rebuild but then my mate swapped it with mine as his wasent revving properly. i dont no maybe the crank needs to be run in or freeing up or something?
    Doesnt have clutch assemly but got malossi variator, laser x pro chrome exhaust and loads of other bits and peices just ask :D Offers :D
  2. Hursty
    Hursty New Member
    pm me what u lookin at money wise.. is it a standard engine ?
    and not revving properly ??
    ben.
  3. steve-k
    steve-k New Member
    pm me ur a price ur after mate ;) and wat needs replacing to get the engine runnin well agen? cheers
  4. Major Rel14b1lty
    Well all it needs is a gudgeon pin top end wise.
    Bottom end wise its fine just had a new crank with less than 50 miles done on it.
    But the clutch assembly isent there but i can supply some clutch parts but the big 35mil nut is fragiled i think that was the problem why we changed it all i need to have a look.
    Open to offers because i just want rid of it. I wont be offended by low offers so just go for it lol. :D
    Also got other bits and bobs so just ask.
  5. Hursty
    Hursty New Member
    a m8 of mine wants it ;) .. is the thread (where the bid nut goes) ok ?
    and £50.. concidering silly offers are welcome ;)
    ben./
  6. Major Rel14b1lty
    ok, its a brand new cylinder and piston, and rings ect, but old head, i will fit the cylinder and torque it all down if you want, but you might want to check but to be honest the cylinder its blaintly brand new, the crank is brand new, i have a performance reedblock and manifold although the manifold is warped i suppose you could sand it flat? Polini reed, the clutch assembly isent on there, but i can supply rear pulley, clutch, clutch bell and some performance springs, the standard variator is there, i have lots of differnt weight rollers, oil pump is on, and brand new starter motor, i can also supply a wheel and laser x pro for more money.
    Drum shoes included.
    o yer i also have a stage 6 performance reedblock and manifold, differnt from the one mention above, which i think is fuking great got all gaskets and shit everything needed to fit, a 21mil delleorto goes straight into it.
    :D lemmo no wot u want
    i also have various paneels for speedy what im spraying black and selling
  7. fat-joe-sf2
    fat-joe-sf2 New Member
    rear pulleys
    ello mate i see your list of stuff uve got sounds interesting
    my speedfight is fucked atm my belt snapped and caught behind the the rear assembaly and i made the mistake of fuckin the thread that the nut that holds the rear assembaly on so i need to know can i re thread it or do i need the shaft and my pulleys look out of line so ...
    have you got a rear pulley assembaly if so how much what condition is it in?
    and what do i do about the shaft it bolts onto have you got one of thoose and how do i fit it ? any suggestions highly appreaciated cheers
  8. Major Rel14b1lty
    Ok well the shaft is the gear, so your best bet is to replace it>
    Maybe if you have a 70 kit a excuse to get a primary gear kit :D
    Ye i need to see what condition the rear pulley assembly is in but im not sure if i want to sell it seperatly from the engine :D
  9. fat-joe-sf2
    rear pulley
    i am thinking about gettin a 70 kit cos im a fat bastard and i can go the same speed and it wont be straining everything so bad lol but i just wanted to get it back on the road first plus i aint got enogh money to buy the rear pulley and the gear kit
    do you know where i can get a standard primary gear?
