Speedfight aircooled
Discussion in 'The Workshop' started by speedfight warrior, Aug 26, 2011.
  1. speedfight warrior
    speedfight warrior New Member
    Hello everyone I'm new to this forum.... :grin:
    Well i swapped my piaggio zip for a speedfight T reg.
    it has
    polini 70 kit
    race crank
    polini reed block
    standard carb with 100 jet
    open air filter
    racing clutch
    doppler race exhaust
    standard gearing
    standard variator
    Before it was tuned it would do just under 60mph
    and now it only goes 50 ?!?!?! HELP :beg: :beg: :beg:
  2. creditz
    creditz Member
    Speedfight 50 AC
    That really DOES NOT help... what does it do? Bog? Or just slow? More information needed...
  3. speedfight warrior
    Sorry it doesn't bog at all it is just slow....?
  4. speedfight warrior
  5. brettfield999
    brettfield999 Member
    Typhoon 172
    Check your rollers. When were they last replaced? They maybe too heavy for your setup, buy a set and see.
  6. speedfight warrior
    They are brand new rollers...
    3 - 10 gram
    3 - 5 gram
    would this be effecting it, having 2 different sets in, i have tryed every combination under the sun.... :/
  7. brettfield999
    Typhoon 172
    Ideally use the same ones and go up and down, you will feel a gain or a loss of power. Roughly 5s all round me thinks
  8. speedfight warrior
    well when i had just 10 grams in it would hardly move off the spot
    when i put all 5's in it would just scream and take off slowly at a ridiculos amount of rpm..... so when i put 3 of each it was alot better :/
  9. brettfield999
    Typhoon 172
    10grams are too heavy for sure and 5g seems too heavy for your setup also. Its just trial and error. Buy a box of rollers (Stage6 do some) and go from 10 and work downwards until you get the best setup possible
  10. speedfight warrior
    5 grams are too HEAVY ?!?!
    i have some 1.3 gram rollers which i put in, and it wouldn't move at all......
  11. brettfield999
    Typhoon 172
    Typo sorry 5 grams too light!!!
  12. speedfight warrior
    aaaaah right.
    well work it out,
    10 x 3 = 30
    5 x 3 = 15
    sooo all together that as 45 grams.
    and 7 x 6 = 42 grams.
    so not that far out with being inbetween 5 and 10 ???
  13. brettfield999
    Typhoon 172
    I believe you can but ive never mixed rollers. I would rather be happy that all the rollers that are being flung out are the same weight, even distribution. Also have you alternated the 10s and 5s as that may be the problem?
  14. speedfight warrior
    Yeah they were alternaated.... i made sure of this, because i have ocd.
    so everything has to be in some sort of pattern haha
    This is so mind boggling, i just can't think of what the problem could be :( !!
  15. brettfield999
    Typhoon 172
    Throw "stage6 roller" into ebay and i suggest you grab a set to suit yours they do rollers in packs of 4 in 0.5g increments
  16. speedfight warrior
    does 0.5 really make any difference ??
    what weight do you suggest then...?
    from 7 gram upwards ?????
  17. speedfight warrior
  18. brettfield999
    Typhoon 172
    Im not sure on the size. It should be inscribed on your brand new ones you fitted, and I would buy both. £15 for 4 sets or at least a tenner for one from your local scooter shop
  19. speedfight warrior
    Well we already figured out my current setup is running about 7.4 grams...
    This is too heavy or too light ?
    do i buy some 8.5 gram ????
  20. nathan93
    Gilera Ice
    0.5 does make a difference, as has been said above get a pack of rollers that range from 5gram to 10gram and try each set at a time untill it improves, i take it youve got a stiffer torque spring and stiffer clutch springs to suit your setup?
